350D modded and photoshop problems
Postby lizd31 » Mon Mar 08, 2010 1:03 pm
Hi Guys
I am after some advice from you imagers out there.
When opening a DSS Autosave.tif in photoshop CS3 i change from 32 bits/channel to 16 bits / channel.
When the HDR conversion box opens which method do you choose?
Exposure & Gamma
Highlight Compression
Equalize Histogram
or
Local Adaption
The reason i ask is i have always chosen the method Exposure & Gamma (probably because it is the top one in the box).
Opening the DSS Autosave.tif last night and processing in CS3 when i used the Exposure & Gamma method and then used levels and curves the image seemed to bring out a green tint around the edges of the image and a red tint around the central subject !!!
I then put the RAW images , darks, flats and bias frames through DSS again and this time in CS3 i chose the Equalize Histogram method which seemed to eliminate these unusal colour tints
Any views on this ??
Secondly
Which parameter setting do you gys imaged with a Canon DSLR set ?
Parameter 1
or parameter 2
For last nights imaging session i changed the setting on the camera to:
Parameter 2 (i think iread somewhere that this is the most suitable setting)
Could this have caused the problem?
Thirdly
The flats i am taking using a homemade lightbox with my modded 350D i have now (modded by filter removal) which i take purely by using the AV setting on the cameraare coming out a bright white colour.
Previously on my unmodded 350D using the same method the flats were coming out smack on what they should be like ( i.e central on the histogram)
Do i have to use adifferent approach when taking flats through my modded camera ?
all advice very much appreciated
thanks
Graham
lizd31
