Dew heater temperature
Postby EIZO » Fri Dec 08, 2017 1:30 pm
Never having used one before, I have connected up the dew heater and set a thermometer inside to check it
It reaches just above 86f 30c as far as my darkroom thermometer will go
just how warm should they be ?
Thanks
EIZO
Re: Dew heater temperature
Postby dave.b » Fri Dec 08, 2017 5:43 pm
The purpose of the dew heater is to compensate for the radiated energy being lost from the front optical assembly of a telescope. Hence the temperature of the front assembly is a function of thermal energy input less thermal energy lost, i.e. radiated. You therefore need to use the dew heater to add enough thermal energy to keep the temperature of the front assembly above the dew point to avoid condensation. You can add more, but for little gain. In fact you might set up thermal air currents inside the OTA that impact on its optical performance.
dave.b
Postby EIZO » Fri Dec 08, 2017 7:05 pm
Thank you easy when you know how :)
EIZO
Postby Aratus » Fri Dec 08, 2017 8:30 pm
It is actually the temperature of the lens/corrector plate which is the determining factor rather than the temperature of the strip. Measuring the temperature of the glass is not easy, so it's a matter of trial and error. You should always use a controller unit, and if dew has already formed, slowly increase the control until it gets rid of it. At first you might need to flick a torch on and off to check if the setting has got rid of the dew, but after a while it becomes instinctive. I know that in the summer it is enough to put it on the lowest setting. As autumn approaches it needs to be set to 1/4 increasing to 3/4 in winter. I tend to put it on a bit higher to compensate for higher humidity levels if dew is forming heavily on other surfaces. It does no harm to flick a red torch on and off quickly just to check the front glass from time to time.
As has already been hinted at, you shouldn't simply bung it on to full every time. It's a waste of power, and it might degrade your observation. I'm a fairly new convert to dew strips, (about 3 years) and I wish I had discovered them earlier!
Aratus
Postby EIZO » Fri Dec 08, 2017 8:45 pm
EIZO
cron
