ETX-125 AT- moon photography problems
Postby Majed » Sat Apr 28, 2018 9:37 am
Hello my friends,
I am new here, my name is Majed. I hope to learn from you all that is new,
My first question about Meade ETX-125 AT, Two nights ago photographed the moon through this telescope by used (T-mount) part number 07384LF and Meade # 64 T-adapter to connect the camera canon 600d
But I could not fit the moon disk inside the picture !!!!!!!!!!!
So I got in touch with Meade customer service and asked if there was a focal reducer for this telescope, and told me this is not anything ever made or sold for ETX.
So I need your advice and opinions as experts on the subject
Majed
Re: ETX-125 AT- moon photography problems
Postby Gfamily2 » Sat Apr 28, 2018 1:18 pm
Hi Majed, and welcome.
The ETX-125 is a Maksutov design telescope, so it has a relatively small field of view.
I can't advise about a focal reducer, though this article here suggests you might be able to get a "back cell adapter" which allows you to use one.
However, for imaging the Moon, a simple alternative is to take 4 overlapping images with the same exposure settings and use software such as Microsoft's Image Composite Editor to combine them into a mosaic covering the whole disc.
ICE is very simple to use, you just select your 4 partial images and it matches up the joins to make a complete image which you can then save
Best of luck, and we look forward to hearing more from you about your astro adventures.
Edited to add
Here's a mosaic assembled by ICE from 28 individual images - it's not particularly good, and I've not done a lot of Post Processing, but it shows what can be done.
Moon 9 May 2017_stitch adj reduced.jpg (243.1 KiB) Viewed 1677 times
Postby Majed » Sat Apr 28, 2018 5:03 pm
Thank you for your quick response to my question
But now I'm planning to buy : Meade Back cell adapter - Etx to SCT threat #
07036
Meade f/6.3 Focal Reducer / field flatterer
Does the problem end?
Majed
Postby Gfamily2 » Sat Apr 28, 2018 5:12 pm
I'm afraid I couldn't tell you, but it sounds interesting, and if it works it'll make your scope a lot more versatile.
Let us know how you get on.
Postby Majed » Sat Apr 28, 2018 5:21 pm
I do not want to risk, especially I will buy them from outside the country,
so I need clear advice if possible
Majed
Postby Gfamily2 » Sat Apr 28, 2018 7:37 pm
Majed wrote:I do not want to risk, especially I will buy them from outside the country,
I'm very sorry then, that I can't advise any further; but do try taking the multiple images and combining them in ICE. It really is very straightforward.
Postby Majed » Sat Apr 28, 2018 8:02 pm
I think this method may not be useful, because I am now planning to photograph the total lunar eclipse on July 27, 2018, and for me better to be prepared early
any way thanks for your time
Majed
Postby Gfamily2 » Sat Apr 28, 2018 10:18 pm
Majed wrote:I think this method may not be useful, because I am now planning to photograph the total lunar eclipse on July 27, 2018, and for me better to be prepared early
If you've decided not to risk buying a focal reducer across the border, you may as well try out using the multi-image approach.
A lunar eclipse occurs over a long period of time, and you only need to move the scope a small amount each time, so it doesn't take long to take a set.
I'd suggest you try it out as practice at the upcoming Full Moon and see how straightforward it is.
Postby Majed » Sun Apr 29, 2018 9:52 am
I want to get it. I want to try something new. Acquire new knowledge to develop my skills in astrophotography . But at the same time I want professionals to give me their advice.
I already have other telescopes and zoom lenses but I have not used this telescope (ETX-125 AT) before in astrophotography .
Majed
Postby Majed » Sun Apr 29, 2018 5:21 pm
Tonight I will take some pictures of the full moon
Majed
Next
