Sky at Night Calendar, a problem.
A place for general chat about Sky at Night Magazine
Postby nebogipfel » Thu Apr 14, 2011 7:46 pm
I know it's free and this is going to sound a bit ungrateful but the calendar doesn't really work.
If you hang it on the wall as intended the corners flop over and you can't see most of the image. I suspect it's asking a bit much to suggest it's printed on stiffer material but if it had a stiff cover a discrete paper clip on each corner would hold the beautiful images flat and therefore visible .........just a suggestion of course [;)]
nebogipfel
RE: Sky at Night Calendar, a problem.
Postby tim allan » Sat Apr 16, 2011 4:46 pm
That may just be your calendar as mine hangs perfectly flat.
tim allan
Postby nebogipfel » Sat Apr 16, 2011 8:06 pm
[quote]ORIGINAL: Tim Allan
[/quote]
That's odd, perhaps it is just mine?
nebogipfel
Postby 47Tuc » Fri Apr 22, 2011 1:53 pm
No, mine has the same problem. :(
47Tuc
Postby nebogipfel » Fri Apr 22, 2011 5:30 pm
That's a relief Paul. [:D] To be honest I can't see how flimsy sheets of paper can be self supporting?
Most calendars are printed on a heavier weight paper. I know it would cost a bit more but as it's only once a year ......
The alternative, of course would be to make it separate from the magazine with a spiral binding/hanger
nebogipfel
Postby 47Tuc » Sat Apr 23, 2011 2:56 am
I want make it clear to the editors however, that I would MUCH rather have a slightly floppy calendar than no calendar at all!! As I've said elsewhere I think the calendar is a terrific bonus.
47Tuc
Postby nebogipfel » Sat Apr 23, 2011 4:33 pm
[quote]ORIGINAL: 47Tuc
[/quote]
Yes, but as my dear old mother used to say, "if a thing's worth doing ........."[;)]
nebogipfel
Return to General
