Skywatcher Heritage 90 Virtuoso Telescope HELP!
Postby Lesroy78 » Sat Jan 06, 2018 3:56 am
Hi to all,
I am new to the world of telescopes. I have just purchased the Skywatcher Heritage 90 Virtuoso Telescope (actually my daughters Christmas present, but sure she will share!). Had a couple of hours playing time so far. Currently just trying to observe the moon and getting used to the scope. The images I am getting at the moment seem very fuzzy (even compared to the naked eye). 10mm and 25mm lens the same. I have currently only been able to use in an urban setting (back garden). I am looking for any tips/help/links please.
My daughter is 5 and is keen on the solar system and planets and do not want my lack of knowledge on using the telescope to put her off.
Any help would be greatly appreciated!
Lesroy78
Re: Skywatcher Heritage 90 Virtuoso Telescope HELP!
Postby Gfamily2 » Sat Jan 06, 2018 10:20 am
Lesroy78 wrote:Hi to all,
I'm surprised by this, as the type of scope (known as a Maksutov) is normally very good at keeping in proper alignment.
Have you tried the scope during the day on distant objects - are you satisfied that it's basically working OK?
For example, when you adjusted the focus, using the knob next to the eyepiece, did you get a change in the quality of the view? If not, the focuser may have become detached (unlikely, but possible).
If it's got a serious problem, it would be a case of getting a replacement from your supplier.
A possibility, depending on how long the scope had been out, is simply that dew had collected on the front of the scope. A hair dryer can help get rid of dew.
Just a few thoughts, maybe someone else can suggest other
Postby EIZO » Sat Jan 06, 2018 11:51 am
Like everything it is the problem with the user not the scope, you have to get used to using it
https://www.youtube.com/watch?v=oySbet53cnI
It is a good scope BUT, I would never use it as it comes I would mount it on a STABLE tripod, never a table or anything less than a SOLID platform
Stupid question, you are focussing it aren't you, and have the eyepiece all the way in, remember also this is a very small aperture scope, so don't use too high a magnification
Finally, Planets, the best you will see with this scope is about this for Saturn and Jupiter
EIZO
Postby Aratus » Sat Jan 06, 2018 12:28 pm
There should be no problem in achieving a good, sharp focus with this telescope. To sum up, there are only 4 things that might be the problem. Firstly condensation on any glass surface. It shouldn't be a problem when you first take the telescope outside, but eventually dew will form, especially in the humid air we are getting at the moment. Bring it back inside, and use a hair dryer on low setting. Secondly trying to view through a window, or even from indoors generally will give a bad image. You need to be outside. Also, check that no plastic protection is still on the front glass plate. Thirdly, you have not put the telescope together correctly. The 'star diagonal' goes in first (the triangular looking thing) and then the eyepiece. Each part needs to be fully pushed in. Fourthly - you need to use the focus knob to achieve a focus. Rotate the knob until you get a good focus. If you get to the end of the mirror movement you need to turn it back the other way.
Check all these things and come back to us if there is still a problem.
This is an excellent telescope for moon and planets. The only problem at the moment is the lack of planets in the evening sky, but that will change. :D
Aratus
Postby Lesroy78 » Sat Jan 06, 2018 3:54 pm
To everyone who has taken the time to respond, we thank you very much. We are continuing to learn on this new subject and appreciate all the help. Will reply when the opportunity to test some things out presents itself . If anyone has any useful links for any info for beginners it would be appreciated . Many thanks L and I
Lesroy78
Postby EIZO » Sat Jan 06, 2018 5:58 pm
Links to and for what there are hundreds
http://www.skyatnightmagazine.com/astro ... -beginners
EIZO
Postby The Man with the Corrugated Iron Roof » Sun Jan 14, 2018 8:39 pm
There's loads of stuff here, not just on the site but also external links to other useful pages:
http://www.philippughastronomer.com/
Also, look out for Phil's Scribblings:
http://www.philippughastronomer.com/Phi ... ingst.html
