Our Solar System is home to hundreds of moons, but how many can you observe?
Find as many of the Solar System’s moons as your optics – and skies – will allow
Some – like our own and the brighter ones around Jupiter and Saturn – are relatively easy to see with the naked eye, binoculars or a small telescope.
Mars at opposition Robert Smith, Stevenage, Hertfordshire, 7 December 2022 Equipment: ZWO ASI178mc camera, Celestron AVX 9.25-inch Schmidt-Cassegrain reflector, Celestron AVX mount
Credit: Robert Smith
Jupiter and its moons David Hoskin, Halifax, Nova Scotia, Canada, 24 August 2023 Equipment: ZWO ASI224MC colour CMOS camera, Celestron C8 XLT Schmidt-Cassegrain, Sky-Watcher EQ6-R mount
Jupiter and its moons by David Hoskin, Halifax, Nova Scotia, Canada, 24 August 2023. Equipment: ZWO ASI224MC colour CMOS camera, Celestron C8 XLT Schmidt-Cassegrain, Sky-Watcher EQ6-R mount
Some even claim that Jupiter’s outer Galilean moons, Callisto and Ganymede, can be seen without equipment when at elongation – though this would be a serious challenge, even for those with exceptionally keen eyesight!
Jupiter and Saturn
Saturn and its moons Sreesha Belakvaadi, Bangalore, India, 1 May 2021 Equipment: ZWO ASI290MC colour camera, Celestron 9.25” SCT, iOptron CEM40 mount
Saturn and its moons, captured by Sreesha Belakvaadi, Bangalore, India, 1 May 2021. Equipment: ZWO ASI290MC colour camera, Celestron 9.25” SCT, iOptron CEM40 mount
You can see some, if not all, four Galilean moons using binoculars, provided you can hold them steady.
For more information, read our guide to observing Jupiter's moons.
The same goes for Titan, the largest and brightest of Saturn’s moons, though the fainter, amateur-accessible ones require at least a telescope.
For more information, read our guide to observing Saturn's moons.
Mars
A view of Mars captured by Pietro De Gregorio, Sorrento, Naples, Italy, 22 February 2025. Equipment: ZWO ASI 485MC camera, Celestron C11 Schmidt-Cassegrain, Barlow 2, 25X Baader, IR/UV cut filter
Mars has two faint moons, but these can only be glimpsed at a time near opposition and preferably a favourable one at that.
Sadly, you’ll have to wait until February 2027 for the next Mars opposition, and it’s not particularly favourable.
Being small, Phobos (diameter 22km) and Deimos (diameter 12km) require a steady night and a large image scale to be caught.
You’ll probably need to put those on the back burner for now.
Uranus and Neptune
Photo of Uranus and its moons. Credit: Pete Lawrence
The outer planets, Uranus and Neptune, have a good number of natural satellites, but many are too faint to see with amateur kit.
In the case of Uranus's moons, there are five that may be seen, although – as with Mars – you’ll need a good image scale to grab them.
You’ll have to set your camera to overexpose the planet in order to catch the moons.
Oberon, Titania, Umbriel and Ariel shouldn’t prove too hard for planetary imaging setups, but the inner moon Miranda can prove elusive and take several attempts.
Neptune and its largest moon Triton imaged through a 356mm telescope. Credit: Pete Lawrence
For Neptune, it’s the planet’s largest moon, Triton, that’s within reach. Surprisingly for such a distant world, Triton is relatively easy to capture.
Neptune typically shines at around mag. +7.9, while Triton hovers near 13th magnitude.
For visual attempts, use a large aperture and high-power eyepiece, ideally on a night of steady seeing.
The same goes for imaging: an extended exposure that over-exposes the planet should reveal the presence of this 1,700km-diameter moon.
It may take a while to record all of these moons, especially since capturing Phobos and Deimos requires waiting for a favourable opposition of Mars.
Keep a log of the ones you’ve observed, and once you’ve covered the more accessible targets, there are still a few fainter and more challenging moons around Jupiter and Saturn to extend your moon-hunting adventure even further.
Solar system moons key observing info
Name Planet Mag. (typical) Difficulty Notes
Luna Earth –12 Easy Naked eye
Phobos Mars +12 Hard Needs favourable opposition
Deimos Mars +13 Hard Needs favourable opposition
Io Jupiter +6 Easy Small scope
Europa Jupiter +6 Easy Small scope
Ganymede Jupiter +5.5 Easy Small scope
Callisto Jupiter +6.5 Easy Small scope
Mimas Saturn +12.9 Tricky Stays close to Saturn
Enceladus Saturn +11.7 Moderate Remains relatively close to Saturn
Tethys Saturn +10.2 Easy Small scope
Dione Saturn +10.4 Easy Small scope
Rhea Saturn +9.7 Easy Small scope
Titan Saturn +8.3 Easy Small scope
Hyperion Saturn +14.2 Moderate Dim, swings wide of Saturn
Iapetus Saturn +10.2 to +11.9 Easy Brighter when west of Saturn
Phoebe Saturn +16.5 Hard Large, highly inclined orbit
Miranda Uranus +16.5 Hard Stays close to Uranus
Ariel Uranus +14.4 Moderate Large scope or planetary imaging setup
Umbriel Uranus +15 Moderate Large scope or planetary imaging setup
Titania Uranus +13.9 Moderate Large scope or planetary imaging setup
Oberon Uranus +14.1 Moderate Large scope or planetary imaging setup
Triton Neptune +13.5 Fairly easy Large scope or planetary imaging setup
Share your Solar System moon observations and images with us by emailing contactus@skyatnightmagazine.com
